Hyfire VIa Wiring, Help ! |
MarkV |
Mar 27 2006, 12:30 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I installed a Hyfire VIa yesterday. The car starts up and idles fine. Took it for a spin and it shut off after about a block. It will restart but then dies again. Made it home after restarting it 3 or 4 times. Can't restart it without using the starter, won't restart with momentum & the clutch.
I am using a Mallory dual point dizzy & a Pertronix 1.6 ohm Blaster coil w/ no ballast. It is wired as follows: I have the large red wire going to the battery & the large black wire to chassis ground. The small black wire to the - side of the coil & the orange wire to the + side of the coil. The white wire goes to the points lug on the dizzy. The small red key on wire is going to the old + coil wire from the harness. Oh & my tach doesn't work. Hooked the tach trigger wire up to yellow wire from the box and the tach does nothing. The diagnostic LED glow solid while it is running & shuts off when it dies. |
MarkV |
Mar 27 2006, 02:08 PM
I flipped the dip switches to 4cyl operation per the instructions.
The coil doesn't get hot. The LED is supposed to flash 3 times when you turn the key on, it doesn't. If I apply 12v to the small red wire via the battery the LED does flash 3 times. The instructions say to wire the small red wire to a key on 12v source. Seems like the coil 12v + wire from the harness is the best source so that is how I have it wired. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I expected a problem with the tach. I have an extra tach that I may modify with a jumper & see if that works. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:03 AM |
