M caliper, Banjo fittings |
DanT |
Mar 27 2006, 12:17 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
will they work on a 914-4 front caliper in place of the normal brake hard line fitting?
DanT |
Mar 27 2006, 04:35 PM
I thought you would figure it out Eric.
I am doing the cardinal no...no. I put my 914-4 fronts on the rear. I know, I know....piston sizes and all that. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I just did not like the adjusting and all with the 914-4 rears. PITB. My hang up. I like just compressing the pistons and sliding in some new pads....clean simple, quick. Espeically at the track. got spoiled with my 944 turbo and Boxster at the track. I am running M calipers up front with vented rotors and Porterfield R-4Es and basically stock PBRs on the rear with a "T". I am going to give it a try and see how it works. I had a 914-6 with JFZ 4 piston calipers at all 4 corners that worked very well. The Ms and the stockers will give me some front bias....we will see. I still have the stock rears so if it doesn't work out I will go back to the stock rears with competition pads. Nothing ventured nothing gained....sometimes you just have to try it yourself. And maybe screw up or maybe not. I was going to use a banjo fitting to hook up the front calipers to the rear hard lines...but just "readjusted the existing hard lines to work without the banjos. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:38 AM |
