mega squirt???, just kicking around |
toon1 |
Mar 27 2006, 11:53 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I am suspecting the pressure sensor is bad in the $hit box. With that thing getting harder and harder to find I was thinking MS might be the way to go.
It seems that the money part is pretty close and reading the archives I think I have accses to everything I need. I just wanted some opinions, pro's and con's, etc... what do you guy's think?? |
toon1 |
Mar 27 2006, 09:06 PM
will the 1.7 air box work? I did a leakdown test on the MPS and it held good vac.. I found a vac. leak at the runner/ head gasket. I have just replaced the intake gasket(thick material) and wet sanded the runner surface on a peice of granite tile to get it flat. The leak is in the same place as before. Is it possible for the runner to crack?? I still have a miss and hesitation between idle and 2500 (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:51 AM |
