Hyfire VIa Wiring, Help ! |
MarkV |
Mar 27 2006, 12:30 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I installed a Hyfire VIa yesterday. The car starts up and idles fine. Took it for a spin and it shut off after about a block. It will restart but then dies again. Made it home after restarting it 3 or 4 times. Can't restart it without using the starter, won't restart with momentum & the clutch.
I am using a Mallory dual point dizzy & a Pertronix 1.6 ohm Blaster coil w/ no ballast. It is wired as follows: I have the large red wire going to the battery & the large black wire to chassis ground. The small black wire to the - side of the coil & the orange wire to the + side of the coil. The white wire goes to the points lug on the dizzy. The small red key on wire is going to the old + coil wire from the harness. Oh & my tach doesn't work. Hooked the tach trigger wire up to yellow wire from the box and the tach does nothing. The diagnostic LED glow solid while it is running & shuts off when it dies. |
MarkV |
Mar 27 2006, 10:26 PM
It's not that close to the motor. Mounted on the rear firewall on a bracket I made. I dont want to mount anything on the front firewall. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:00 PM |
