| jsteele22 |
Mar 30 2006, 01:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
A couple of weeks ago, someone started a thread about DIY headers. Since I'm susceptible to that sort of thing, I got a book about exhaust design, and I've been trying (successfully so far) not to order Covell's "Working With Tubing" video, that Mueller suggested. The conclusion of that other thread seemed to be : don't DIY unless you really, really have to, or really, really want to. So for this thread, I'd like to find out if there's a need for custom headers for an EJ25/914 conversion, or if there is any reasonably affordable stock solution that works. And also to see what folks who are already driving conversions are using : stock manifolds, custom headers, ???? So far, my impression from looking at pictures is that the available Subie headers make too gentle a bend as they come down from the exhaust flange, ending up about as low as the stock oil pan. Not a problem in a Subie, but for us that's getting awfully close to pavement. Although sharp bends are usually undesireable, right near the heads they seem to be less of a problem. Also, I have no idea how they relate to various engine mount bars that people are using. Another issue is primary length. For a 914, I think it would be more fun to emphasize torque at the mid RPM band, as opposed to the top end, so longer, smaller-diameter primaries would be the way to go. Finally, the Smith book ("The scientific design of exhaust and intake systems", Philip Hubert Smith) talks about two categories of exhaust : "Interference" where reflections from one cylinder makes a significant contribution to scavenging from other cylinders, and "Independence", where the scavenging for each cylinder is almost entirely due to reflections from that cylinder. Most headers I see in piuctures look like the Interference type. Given that header design is so complicated and trial-and-error in nature anyway, I would think that the Independence approach would be less prone to failure. The key to the Independence approach is that the primaries do not merge in the standard Y connection into a slightly larger pipe, but enter an "exhaust box" (it's an old book, so the terminology is probably out-of-date) which has a fairly large volume, say 12-15 times larger than the displacement of one cylinder. Each pipe enters the box directly with no merge. So when a pulse comes down one pipe, it only increases the pressure in the box a small amount, resulting in very weak reflections going up the other pipes; but the original pipe sees a strong (negative pressure) reflection from the exhaust box. So there's really only two parameters to tune : primary length and diameter. Shortly after the exhaust box comes the "silencer", which is pretty much a standard glass-pack muffler. Anyway, this last part was about how a custom design might look. But lets hear it : what are all you Converts out there (thinking of) using ? |
| lapuwali |
Mar 30 2006, 04:29 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
There haven't been, to my knowledge, any books dedicated to intake and exhaust design (not seriously, anyway, mostly how-tos on how to replicate a common V8 header, for example), at least not for the general public. Perhaps there are some SAE papers available. There have been a number of books published that cover the topic, however. Bell wrote a couple of books that cover the subject, though even those are 20 years old or more. There's also Taylor's general IC engine books. Scientific studies of the problem are very sparse in general literature, however. Again, the SAE, or the British equivalent, would be most likely to offer anything. Something like Ricardo's work really needs to be published again, and I suspect Taylor's work was an attempt at this. The field has gotten so big, and generally so focused on just meeting regulations, that I doubt it will happen. Tuners are rarely all that science-minded, and even then are frequently not interested much in theory, and even then are loath to publish for commercial reasons. Ricardo's own organization has grown into a very lucrative consulting operation which sells its research. The fact that Smith is still in print after all this time suggests there's a ready market for such a book, but will require someone bright enough to realize that most readers will never be in a position to buy their tuning services (geographical, say), or will go to them to have them done, and very few people will "steal" the research to enrich themselves. Advertising that's not only free, but you get the (tiny) amount of money from the book sales, too. |
jsteele22 Subie Conversion : What about exhaust ? Mar 30 2006, 01:42 PM
TonyAKAVW Mostly due to simpliticy, I'm planning on usin... Mar 30 2006, 01:54 PM
lapuwali The Smith book, as you say, is an old book (I also... Mar 30 2006, 02:05 PM
Hydra I first thought about using the suby's headers... Mar 30 2006, 02:19 PM
jsteele22 ... Mar 30 2006, 03:35 PM
jsteele22 ... Mar 30 2006, 03:53 PM
lapuwali ... Mar 30 2006, 05:10 PM
lapuwali Maybe, maybe not. If Jake finds it adequate to us... Mar 30 2006, 06:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 10:13 PM |
