jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
To all you uber experts:
I dug up three MPS's from the crate and tested them 1) 043 MPS. Lost 6 inches Hg over 5 minutes. Tested at 91 and 338 ohms. 2) 049 MPS. Lost 4 inches Hg over 5 minutes. Tested at 89.7 and 328 ohms. 3) 043 MPS. Would not pull any vacuum, toast. ... So, is #1 any good? If not, can I use the 049 on a 2.0L? Thanks! -Josh2 |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,971 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
#1 and #2 are failing, but probably serviceable, the leaks are not that bad. A good MPS is rock solid, no vacuum loss at 15 inhg forever. Because the MPS diaphragm is held by intake manifold vacuum pulses, it never sees a constant steady vacuum in reality. An MPS with a slight vacuum leak will work fine, sometimes for several years, before it does not adequately function. They fail going too rich.
#3 is a goner. |
Lo-Fi Version | Time is now: 8th July 2025 - 06:43 PM |
