> Jeff’s PEFI Wiring Harness, Your input please…
JeffBowlsby
post Apr 7 2006, 11:32 PM
PEFI (programmable electronic fuel injection) is here to stay and will become a necessity in the future to keep our 914s on the road and I want to be part of that revolution. (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
Studying the different available PEFI systems and 914/4 engine layouts, they are all very similar in terms of their electrical and harness requirements. So I have been working with other club members (EE’s!) who shall remain nameless for the moment, to develop a universal 914 fuel injection wiring harness specific for the 914/4 or type 4 engine, that can be easily adaptable to most of not all aftermarket programmable electronic fuel injection (PEFI) systems. I have attached a couple of diagrams of our ideas and would appreciate anyone’s feedback, because this harness is for all 914/4 owners and I want it to serve our needs to the fullest. If its not a good solution that will serve most peoples needs, then I won’t make them.
The concept of this harness is clear: Create a PEFI harness that is simple, and adaptable to all or most aftermarket PEFI systems, built of high quality parts and workmanship for durability, and be reasonably priced. I realize it won’t meet everyone’s needs, but it should be a good solution for most. My intent is that it be Plug N Play and take the R&D, pain and expense out of building a harness that most dread. Buying this harness gives you reliability and gets you on the road much faster than having to build your own harness. I know some of the PEFI systems have harnesses available, but they are not the best solutions, they are not complete, and they are not made for the 914, although they can be a good start. My PEFI harness features include:
FI systems – A fuel-only PEFI system would be nearly Plug N Play, which I think most 914 owners will want when their MPS dies, most do not want to fuss with complex systems, but this harness will work for those who do. If someone would package an ECU with preloaded maps for specific engines, the install would be nearly painless. I bet the time to install a simple system could be accomplished in an afternoon if coordinated. If ignition control is needed, then my PEFI harness with additional wires, has the expandability to accommodate your needs.
2-piece harness with a weatherproof main disconnect in the engine bay – This allows the production of a standard engine harness configuration which will universally fit all type 4 engines, 1.7, 1.8 and 2.0L. The ECU harness segment can be made to the length you require, so the FI box can be located in the cabin or anywhere you select. The main disconnect allows the harness to penetrate the firewall and become mounted to the chassis, and also allows easy engine drops. Wires on one end of the ECU harness are long (is 18 inches enough?) and not terminated, so you can hook them up to whatever FI equipment in whatever arrangement you want.
Auxiliary wires – The PEFI harness connects all the standard 914/4 engine mounted FI sensors and fuel injectors to the ECU controls – TS1, TS2, TPS, and Tach. It connects to power and the fuel pump relay at the stock relay plate and to grounds in the stock engine case location. It is convenient to use the stock D-Jet AAR, controlled through the ignition harness, but if you want a fast idle solenoid or even a stepper motor you can have it. The standard harness includes 4 undesignated auxiliary wires for your use which might serve a fast idle solenoid, stepper motor or ignition trigger. If 4 extra auxiliary wires internal to the harness are not enough (it will be for most people), then I can provide as many as you like for an additional charge using a different main disconnect configuration.
TPS – At additional cost, I will provide a new TPS potentiometer with a disconnect and casing, or you can send me your TPS and I will install the disconnect and casing.
Connection hardware - D-Jet hardware is standard (new boots!) so you can reuse the stock FI components. Optional L-Jet connectors can be installed for a small cost increase. The harness can be configured for FI power resistors, or not, depending on your needs.
WBO2 cable – Use the cable from the WBO2 manufacturer and run it separately from the FI harness to keep things easy and protect the WBO2 warranty.
High Quality - The PEFI harness cable is fully cased to protect the internal wiring from chafing, fluid contamination and heat damage. All new, high quality parts and workmanship are used in its construction, this harness does not use any old parts and there is no core charge, although I might buy your D-Jet harness for my D-Jet harness customers. The Tach wire includes a shielded ground.
Price – What might all this cost? I honestly don’t know yet, but considering the parts cost purchased in bulk quantities, and the amount time required to make them, I think I can make them available in the $400-450 range or thereabouts. Is this price range reasonable? If not, where does the price need to be for you to buy one?
So talk to me my esteemed colleagues…and thanks in advance. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) My intention is to bring these on line in the next few weeks if possible.
DNHunt
post Apr 8 2006, 07:47 AM
914 Wizard? No way. I got too much to learn.
Jeff
Harnesses made by you would be great. But, in my opinion it needs to be in a package with the ECU and probably the WBO2 controller and sensor. Even then is there enough of a market to make it work? No one would like to see you or anyone else stuck with product they can't sell.
Fuel only PEFI although welcome may be a little short sighted also because there are people who will want crankfire as long as they are going to the trouble. Add to that distributors are old and worn. I think you would have to include provisions for DIS.
One thought would be to buy preassembled MS kits and program them for stock configurations. To keep costs down the kits could be assembled from components. Possibly a deal could be worked out to buy them at a discount. WBO2 would probably have to be bought at retail price. One could collect the program files and burn them to CDs. If ECU's were bought in quantity maybe named brand brains could be used (longshot I think).
People would still have to realize that optimum tuning would require tweaking at the least and probably dyno time.
I would suggest that a WBO2 be manditory because otherwise the program is hit or miss. There are just too many variables with our cars and their age.
The problem with providing parts specific to the 914 is that the market is so small it will only support cottage industry and therfore there is no cost reduction as a result of quantity. I have a hard time seeing any opportunity for profit in this. Provided the people putting it together were satisfied with doing it for the greater good and maybe a little (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) money, it might fly. But, if there had to be minimum quantities of supplies purchased and money at risk, the greater good may not be enough compensation.
As much as I love these cars, it's tough to see anything positive in them from a business point of view.
Dave
Jeff Bowlsby   Jeff’s PEFI Wiring Harness   Apr 7 2006, 11:32 PM
Jeff Bowlsby   Potential FI box layout for simple fuel-only D-Jet...   Apr 7 2006, 11:33 PM
DNHunt   Jeff Harnesses made by you would be great. But, i...   Apr 8 2006, 07:47 AM
Jeff Bowlsby   Thanks for taking the time to comment Dave, most e...   Apr 8 2006, 09:25 AM
Tobra   It seems to me that people do rebuild motors and t...   Apr 8 2006, 09:51 AM
lapuwali   Random thoughts: I would argue that one reason ev...   Apr 8 2006, 10:29 AM
Jeff Bowlsby   I am with you James, I see things the same way. <...   Apr 8 2006, 11:48 AM
Dominic   Jeff, Just wanted to chime in....I have a Perfect ...   Apr 8 2006, 01:50 PM
lapuwali   Dominic, the trick is attaching things to the bare...   Apr 8 2006, 02:44 PM
Jeff Bowlsby   Thats exactly the plan. The ECU harness segment i...   Apr 8 2006, 02:52 PM
bernbomb914   Jeff I would be interested in your harness when I ...   Apr 8 2006, 06:48 PM
Jeff Nelson   I think that ignition control is an important part...   Apr 9 2006, 12:54 AM
Mueller
- Lo-Fi Version Time is now: 4th July 2025 - 11:03 AM
