| tod914 |
Sep 20 2003, 08:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
2 weeks ago I did some clean up in the engine bay. I was carefull with the water, but apparently a few things got wet. I did not start the car afterwards like I should of. Today I spent the morning cleaning every electric leed and connection. Grounds, Relay board, injector conections, distr cap, plugsl etc.
with wd40 to dispurse any water and contact cleaner. The car is a 2.0 with pertronix. I tried starting fluid in the throttle body. It runs for a sec then dies. The fuel pump is working and it the starter and ign. are good. Any tips on where to look next? |
| tod914 |
Sep 20 2003, 10:54 AM
The vacuum lines are new. The order of the wires has not been changed. I did 1 at a time. The cap is on correct.
Could fuel injection trigger points cause a problem like this? I dont know how to pull the distrubutor to check or what to even look for. Bad throttle body switch? even though its 1 year 1/2 old? Bad CPU? Volt reg is new. I check the relays in the relay board they are fine. No blown fuzes. Battery seems to crank well. Maybe I should pull an injector amd see if its gettn fuel? |
tod914 Need help car wont start Sep 20 2003, 08:43 AM
URY914 Check all the spark plug wires.
Check the distr i... Sep 20 2003, 09:14 AM
Air_Cooled_Nut If the car does actually run (fire) then die you c... Sep 20 2003, 10:37 AM
Brad Roberts Its fuel related. I bet you hear the pump for the ... Sep 20 2003, 11:00 AM
tod914 just tried that Brad. No dice :( Sep 20 2003, 11:20 AM
Brad Roberts Can you hear the fuel pump prime ??
B Sep 20 2003, 11:21 AM
Brad Roberts Stay online. You have my attention for 20 more min... Sep 20 2003, 11:22 AM
tod914 yes it primes Sep 20 2003, 11:22 AM
tod914 Brad if its any easier for you, and you have a few... Sep 20 2003, 11:26 AM
Brad Roberts This is actually easier. The wife really gets tire... Sep 20 2003, 11:33 AM
tod914 Brad,
Im sure you get bombarded with calls. No p... Sep 20 2003, 12:47 PM
Brad Roberts I sent you my cell number.
I use the relay to cy... Sep 20 2003, 12:54 PM
Bleyseng Just switch out the fuel pump relay with a headlig... Sep 20 2003, 01:38 PM
RustyWa Here's another thing to go look at. It worked... Sep 20 2003, 01:55 PM
tod914 Ok making real good progress with special thanks t... Sep 20 2003, 03:29 PM
Howard Tod, I'm banging my head against the wall with... Sep 20 2003, 09:38 PM
tod914 Howard, with mine, it primes.
The car has spark... Sep 21 2003, 05:36 AM
Brad Roberts I must admit.. you where very quick with my sugges... Sep 21 2003, 05:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:32 PM |
