> Need help car wont start
tod914
post Sep 20 2003, 08:43 AM
2 weeks ago I did some clean up in the engine bay. I was carefull with the water, but apparently a few things got wet. I did not start the car afterwards like I should of. Today I spent the morning cleaning every electric leed and connection. Grounds, Relay board, injector conections, distr cap, plugsl etc.
with wd40 to dispurse any water and contact cleaner.
The car is a 2.0 with pertronix. I tried starting fluid in the throttle body. It runs for a sec then dies. The fuel pump is working and it the starter and ign. are good.
Any tips on where to look next?
Bleyseng
post Sep 20 2003, 01:38 PM
Aircooled Baby!
Just switch out the fuel pump relay with a headlight one. Be sure to clean the contacts where they plug in as I bet its that greenishcrap that is stopping the relay from working.
If you have some di-electric silicon lightly coat the prongs before inserting the relay.
Geoff
tod914   Need help car wont start   Sep 20 2003, 08:43 AM
URY914   Check all the spark plug wires. Check the distr i...   Sep 20 2003, 09:14 AM
Air_Cooled_Nut   If the car does actually run (fire) then die you c...   Sep 20 2003, 10:37 AM
tod914   The vacuum lines are new. The order of the wires ...   Sep 20 2003, 10:54 AM
Brad Roberts   Its fuel related. I bet you hear the pump for the ...   Sep 20 2003, 11:00 AM
tod914   just tried that Brad. No dice :(   Sep 20 2003, 11:20 AM
Brad Roberts   Can you hear the fuel pump prime ?? B   Sep 20 2003, 11:21 AM
Brad Roberts   Stay online. You have my attention for 20 more min...   Sep 20 2003, 11:22 AM
tod914   yes it primes   Sep 20 2003, 11:22 AM
tod914   Brad if its any easier for you, and you have a few...   Sep 20 2003, 11:26 AM
Brad Roberts   This is actually easier. The wife really gets tire...   Sep 20 2003, 11:33 AM
tod914   Brad, Im sure you get bombarded with calls. No p...   Sep 20 2003, 12:47 PM
Brad Roberts   I sent you my cell number. I use the relay to cy...   Sep 20 2003, 12:54 PM
Bleyseng   Just switch out the fuel pump relay with a headlig...   Sep 20 2003, 01:38 PM
RustyWa   Here's another thing to go look at. It worked...   Sep 20 2003, 01:55 PM
tod914   Ok making real good progress with special thanks t...   Sep 20 2003, 03:29 PM
Howard   Tod, I'm banging my head against the wall with...   Sep 20 2003, 09:38 PM
tod914   Howard, with mine, it primes. The car has spark...   Sep 21 2003, 05:36 AM
Brad Roberts   I must admit.. you where very quick with my sugges...   Sep 21 2003, 05:42 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:50 AM
