> Need help car wont start
tod914
post Sep 20 2003, 08:43 AM
2 weeks ago I did some clean up in the engine bay. I was carefull with the water, but apparently a few things got wet. I did not start the car afterwards like I should of. Today I spent the morning cleaning every electric leed and connection. Grounds, Relay board, injector conections, distr cap, plugsl etc.
with wd40 to dispurse any water and contact cleaner.
The car is a 2.0 with pertronix. I tried starting fluid in the throttle body. It runs for a sec then dies. The fuel pump is working and it the starter and ign. are good.
Any tips on where to look next?
tod914
post Sep 21 2003, 05:36 AM
Howard, with mine, it primes.
The car has spark, injectors click, fuel pump works.
Injectors do not spray. Going to pick up a pressure gauge to read the fuel pressure today and pull an injector to see if it's clogged. I had contamination problems a while back. So wouldnt surprize me if it finally messed things up.
Maybe try swapping the relays like Brad first suggested and check the fuze on the relay board.
Hope your's is an easier fix than mine. On the brighter note, I sure did learn alot.
tod914   Need help car wont start   Sep 20 2003, 08:43 AM
URY914   Check all the spark plug wires. Check the distr i...   Sep 20 2003, 09:14 AM
Air_Cooled_Nut   If the car does actually run (fire) then die you c...   Sep 20 2003, 10:37 AM
tod914   The vacuum lines are new. The order of the wires ...   Sep 20 2003, 10:54 AM
Brad Roberts   Its fuel related. I bet you hear the pump for the ...   Sep 20 2003, 11:00 AM
tod914   just tried that Brad. No dice :(   Sep 20 2003, 11:20 AM
Brad Roberts   Can you hear the fuel pump prime ?? B   Sep 20 2003, 11:21 AM
Brad Roberts   Stay online. You have my attention for 20 more min...   Sep 20 2003, 11:22 AM
tod914   yes it primes   Sep 20 2003, 11:22 AM
tod914   Brad if its any easier for you, and you have a few...   Sep 20 2003, 11:26 AM
Brad Roberts   This is actually easier. The wife really gets tire...   Sep 20 2003, 11:33 AM
tod914   Brad, Im sure you get bombarded with calls. No p...   Sep 20 2003, 12:47 PM
Brad Roberts   I sent you my cell number. I use the relay to cy...   Sep 20 2003, 12:54 PM
Bleyseng   Just switch out the fuel pump relay with a headlig...   Sep 20 2003, 01:38 PM
RustyWa   Here's another thing to go look at. It worked...   Sep 20 2003, 01:55 PM
tod914   Ok making real good progress with special thanks t...   Sep 20 2003, 03:29 PM
Howard   Tod, I'm banging my head against the wall with...   Sep 20 2003, 09:38 PM
tod914   Howard, with mine, it primes. The car has spark...   Sep 21 2003, 05:36 AM
Brad Roberts   I must admit.. you where very quick with my sugges...   Sep 21 2003, 05:42 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:27 AM
