Polishing Anodized Aluminum Trim, There has to be an easier method!!!!!!! |
73Phoenix20 |
May 6 2006, 07:02 PM
Member Group: Members Posts: 334 Joined: 15-June 05 From: Michiana Member No.: 4,283 |
We have all been there and done that! The Anodized Aluminum Trim around the windshield gets nicks and scratches....
Easy, right? Just polish them out and the Trim will look beautiful again... Well, NO, its not easy, but yes, if done properly the trim looks great! My current method is as follows: Sheet of 220 Wet & Dry, Sheet of 600 Wet & Dry, Sheet of 1000 Wet & Dry, Bottle of Blue Magic Metal Polish, Pad of extra fine (000) Bronze Wool (NOT Steel Wool!!!) Tape all around the Trim to be polished (you will slip; no, you aren't that good!) Double up on the blue masking tape; it's cheap! Quarter sheet of 220 grit, folded to 1/4 size. Spray with a mist of 1 quart water and a few drops of dish soap, well mixed. Paper should be damp, but not dripping. Gently sand with the length of the trim, in long, even strokes...medium pressure. Cover the entire piece. Wipe off the black residue with a clean damp paper towel. Repeat. You may need to do this part up to three times! Do the same thing with the 600 grit, then the 1000 grit, using less pressure with each paper switch. Wipe clean between each grit with the damp paper towel. Finally, apply a small spot of Blue magic to a small tight ball of Bronze Wool (boaters with teak know what this stuff is!!!) and again polish the surface in long gentle strokes, with light to medium pressure. When the surface and wool turns black, apply a spot of Blue magic to a clean cotten cloth (rag) and wipe off any trace of residue. Buff with another clean cotten rag. Lean over to see your reflection in the trim... If you can see yourself clearly, you have done it right! If the trim appears to have dull streaks and some polished spots, start over! You haven't gotten thru all of the anodizing yet! NOW, somebody tell me there is an easier method, PLEASE!!! I spent two hours doing just one quarter of my windshield trim, and it was in reasonably good shape to start with. It did come out very nice, but I now have no finger tips left! (IMG:style_emoticons/default/wacko.gif) |
Brew |
May 6 2006, 08:24 PM
That's Captain Moron to you! Group: Members Posts: 391 Joined: 5-August 05 From: Colorado Springs Member No.: 4,546 |
Does windsheild trim not come off the car?
If so, have it professionally polished, or polish it yourself on a buffing wheel equipped bench grinder and then clear-coat it. Otherwise, as a guy with some really nice cars once told me; You can only do the best that you can with what you have to work with. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:30 PM |
