| stephen7 |
May 7 2006, 10:26 PM
Member ![]() ![]() Group: Members Posts: 69 Joined: 4-March 06 From: seattle wa Member No.: 5,663 |
I read that the early cars didn't have rear sway bars - do they make a difference?
I bought expensive weltmeister sway bars for my 911 and all the PCA racers said take them off and it will corner better. How about 914s? Should you have beefy sway bars for AX and DE or run with stiffer springs, dampeners and thicker torsion bars? thanks steve |
| John |
May 7 2006, 10:56 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Our track car has 21mm front torsion bars, a very heavy front sway bar (don't recall the size), 400# rear springs and no rear sway bar.
This car is track only (no auto-x). The car has 245/45-16 Kumho Victo Racers on all four corners. The car is very neutral. We could tell no difference with the rear bar connected, but in the interest to prevent any rear wheel lift (and wheelspin), we removed the rear bar. Now that we have a limited slip differential, this may not be a problem, but like I said, we could tell no difference with or without the rear sway bar. |
| stephen7 |
May 7 2006, 11:10 PM
Our track car has 21mm front torsion bars, a very heavy front sway bar (don't recall the size), 400# rear springs and no rear sway bar. This car is track only (no auto-x). The car has 245/45-16 Kumho Victo Racers on all four corners. The car is very neutral. We could tell no difference with the rear bar connected, but in the interest to prevent any rear wheel lift (and wheelspin), we removed the rear bar. Now that we have a limited slip differential, this may not be a problem, but like I said, we could tell no difference with or without the rear sway bar. when you see the pictures of the guy lifting his front tire on hard cornering - is that due to too stiff a combination of front sway bar/torsion bars? Is a little wheel lift ok? I thought no rear bar would meet with widespread concerns but I stiffer springs and no rear sway bar is a pretty good set up. thanks guys steve |
stephen7 Anybody running without a rear sway bar? May 7 2006, 10:26 PM
Dan (Almaden Valley) depends on your set up and what you want to do wit... May 7 2006, 10:30 PM
Dave_Darling First, I don't believe that early cars had swa... May 7 2006, 10:36 PM
stephen7 what size tires and wheels are you running? Did y... May 7 2006, 10:37 PM
grantsfo I'm running my 914/6 with 21 mm front bar, 20... May 7 2006, 10:38 PM
turboman808 really not a question with a definite answer as yo... May 7 2006, 10:54 PM
stephen7 ![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 09:47 AM |
