Need timing help for my /6 |
Dr Evil |
May 17 2006, 11:14 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Hey all,
My ride is sounding like it wants to start, but I need to know some info that I don't have in my book. Things to check: -Where should I statically time it? -What order do the plug wires go on the dizzy? -What direction does the rotor turn, CW or CCW? I may have missed something, but I know I have spark and that I have been able to adjust the dizzy so that at least one cylinder was hindered upon ignition. I need to re check my wire4s fro sure, but I am looking for some difinitve info. Thanks (IMG:style_emoticons/default/drunk.gif) |
smdubovsky |
May 18 2006, 10:27 AM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Im not used to a 2.7, but you'll need 5-10deg btdc @ idle and 35-40deg @ speed for a single plug. The 911 factory workshop manuals (you have those right? If you don't, send me an email;) describe the 2.7 advance curve. What year / spec motor do you have?
Here is probably the closest one (note the axes are for DISTRIBUTOR - double both for the crank advance and speed) So, if you started @ 5-10deg at the crank, it will give right on 30 deg advance = 35-40deg total at >6000rpm. SMD |
Lo-Fi Version | Time is now: 13th June 2024 - 10:03 PM |
