> brake(s) possibly rubbing?, clueless
Hammy
post May 19 2006, 05:50 PM
mr. Wonderful
Ok, I know absolutely nothing about brakes so excuse the stupid explanation..
Is it possible for the brake pads to be squeezing too tight when they're not supposed to be ?
I have the rear of my car up on jack stands, and (with the e brake off of course), the left rear wheel is somewhat difficult to spin. How easy should it be to spin? The right rear also sounds like its rubbing slightly on the pads, though I'm not sure if this is normally how it's supposed to be? But the left rear definitely has some resistance.
If it isn't supposed to be this way, is it just a simple adjustment or am I going down another deep and dark path... (IMG:style_emoticons/default/ph34r.gif)
This is a shot of the left rear pad...
bondo
post May 19 2006, 05:53 PM
You started down the deep dark path when you got a 914.. (IMG:style_emoticons/default/lol2.gif)
Search for "venting clearance".. it will answer all your questions.. and generate that many plus two new ones. (IMG:style_emoticons/default/smile.gif)
Short answer: No, that's not normal, there should be a measurable gap.
Ctrout
post May 19 2006, 06:38 PM
QUOTE(bondo @ May 19 2006, 05:53 PM) *
I think the gap is either .006" or .008". I set mine just slightly tighter that the recommended specs to get a better "pedal feel" and I get a rather annoying chirp at very low speeds so I'm thinking of just going with what the books say.
Hammy   brake(s) possibly rubbing?   May 19 2006, 05:50 PM
bondo   You started down the deep dark path when you got a...   May 19 2006, 05:53 PM
Ctrout
- Lo-Fi Version Time is now: 6th July 2025 - 06:43 PM
