Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The honeymoon is over with my new 74 914. Sorta. It still runs but has a noticable miss at low loads. It runs through the RPM range nicely and accelerates fine, but has the low load, throttle barely opened miss. I'm new to the 2L FI engine so suggestions welcomed (ie., needed).
About 3 weeks ago about once every 3-4 days of daily driving, under light load, 5th gear, 2500 RPM, the engine momentarily hick-uped, then ran smooth. About 2 weeks ago, the hick-ups became about once a day, under light loads, noticed mostly in 4th and 5th gears, 2-3K RPM. This week on Thursday, on the way to work, the misses became very apparent, again, only under light loads. Yesterday, for starters, I inspected the points, cap, and rotor; nothing unusual. Until I replaced the rotor cap. To make sure I had it on correctly, I wiggled the cap and the entire distributor moved. It was snug where it was but not tight, easily twisted by hand. So I removed the distributor, changed points, rotor, cap, plugs, refurbished the distributor locking strap. Not sure I timed it right as I now hear slight pinging under acceleration. I'll re-time again today. But the missing under light loads is still there. Visual inspection of vaccuum hoses & wires looks ok. Will do the carb cleaner on hoses to check for vaccuum leaks today. What should I check next??? Thanks in Advance, Spoke Attached image(s) ![]() |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
probably a vac leak besides the mis-timing. Use a timing lite to set the timing.
Whats that tee for on the decel small hose??? You might want to upgrade to real German braided vac hoses instead of those rubber USA ones. |
Lo-Fi Version | Time is now: 17th June 2024 - 09:19 AM |
