> My shot at explaining valve adjustment on a 4 pot, Damn near beat death but, maybe this will help somebody
DNHunt
post May 20 2006, 08:10 PM
914 Wizard? No way. I got too much to learn.
I couldn't find Mile's drawing of a cam (it magically made everything make sense to me) so, I decided to try my hand at it.
First, jack the car up so it assumes the usual and comfortable position of a 914. Resting securely on jackstands. I won't get under it without jackstands cause the thing jumps off of jacks. I have a dented long on the driver's side and a dented rocker panel on the other side to prove it
Dave
DNHunt
post May 20 2006, 08:25 PM
The whole process works because the flat aircooled /4s are really beautifully simple. Like lifter on opposite sides of the engine and therefore rockers share the same cam lobe. Dr. Porsche was really clever. #1 exhaust shares the same cam lobe with #3 exhaust, #1 intake with #3 intake, #2 intake with #4 intake and #2 exhaust with # 4 exhaust. When #1 exhaust is on the cam nose and the valve is open # 3 exhaust should be on the valve seat and can be adjusted. The same applies for all of the pairs of valves. Way cool.
At the risk of failing to live up to Mile's tradition here is my drawing of this neat little situation. If you get this valve adjustment is really simple.
DNHunt   My shot at explaining valve adjustment on a 4 pot   May 20 2006, 08:10 PM
DNHunt   Get under the car and remove the valve covers. I...   May 20 2006, 08:14 PM
DNHunt   Here's what you will see. The rocker assembly   May 20 2006, 08:15 PM
DNHunt   The whole process works because the flat aircooled...   May 20 2006, 08:25 PM
DNHunt   As a practical matter lock a road wheel so it will...   May 20 2006, 08:33 PM
DNHunt   I start by watching #2 exhaust and turing until it...   May 20 2006, 08:37 PM
DNHunt   On the opposite side of the engine #4 exhaust valv...   May 20 2006, 08:47 PM
DNHunt   Next rotate the engine until #2 intake is open. Se...   May 20 2006, 08:52 PM
DNHunt   Adjust #4 intake cause it is on the valve seat and...   May 20 2006, 08:54 PM
DNHunt   Rotate until #1 intake is open.   May 20 2006, 08:55 PM
DNHunt   Adjust #3 intake   May 20 2006, 08:56 PM
DNHunt   Rotate a gain until #1 exhaust is open.   May 20 2006, 08:57 PM
DNHunt   Adjust #3 exhaust   May 20 2006, 08:58 PM
DNHunt   Now block the other wheel so you can check the opp...   May 20 2006, 09:00 PM
DNHunt   Check #4 exhaust for full openning   May 20 2006, 09:01 PM
DNHunt   Adjust #2 exhaust   May 20 2006, 09:02 PM
DNHunt   Check #4 intake for full open.   May 20 2006, 09:03 PM
DNHunt   Adjust #2 intake   May 20 2006, 09:04 PM
DNHunt   Ditto for cylinder #3 intake and exhaust. Rotate u...   May 20 2006, 09:06 PM
DNHunt   Adjust #1 intake   May 20 2006, 09:07 PM
DNHunt   Check #3 exhaust.   May 20 2006, 09:07 PM
DNHunt   Adjust #1 exhaust.   May 20 2006, 09:08 PM
DNHunt   Tighten everything and check the valve cover gaske...   May 20 2006, 09:10 PM
DNHunt   I suppose this is a bit of urban myth but, I'v...   May 20 2006, 09:12 PM
mcbain77   Fuchin Classic.   May 20 2006, 09:14 PM
elwood-914   Great Job Dave!! Good luck on your trip ne...   May 20 2006, 10:14 PM
Aaron Cox   very nice. ive always done it like this.   May 20 2006, 10:58 PM
newto914s   Classic for sure! Thanks for the cam drawing, ...   May 20 2006, 11:47 PM
lotus_65   thanks! it couldn't have come at a better ...   May 21 2006, 05:34 AM
Spoke   I like the cam drawing, saves me from reading. Ou...   May 21 2006, 06:08 AM
rhodyguy   very nice dave. you and jerry have a fun drive. k   May 21 2006, 07:05 AM
scottb   dave, very nice write up. what header are you ru...   May 21 2006, 11:35 AM
Tobra   You could never get nice pictures like that with t...   May 21 2006, 12:15 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:13 PM
