terrymason |
Member ![]() ![]() Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 ![]() |
So I spent about 3 hours today with my welder, the first time I've seriously tried welding, and have made progress, but I'm still trying to get it right. I was hoping that you guys could look at some samples of my work, and give me some pointers.
My welder only has a Low and High heat selector, and adjustable wire control. I bought a "how to weld" tape off ebay, and that did give me some help. I'm trying to weld 20 gauge to another larger peice of 20 gauge, and I just tear up the smaller peice without really penetrating the larger one. my welder: (IMG:http://img181.imageshack.us/img181/7029/picture0014ul.th.jpg) front (IMG:http://img268.imageshack.us/img268/1342/picture0039wt.th.jpg) and back (IMG:http://img181.imageshack.us/img181/9079/picture0066rh.th.jpg) What do you guys think I'm doing wrong? (IMG:style_emoticons/default/welder.gif) |
Brew |
That's Captain Moron to you! ![]() ![]() Group: Members Posts: 391 Joined: 5-August 05 From: Colorado Springs Member No.: 4,546 ![]() |
Using flux core wire? Problem #1. On galvanized? Problem #2.
But it looks like you do have some pen on the larger piece, try grinding off the galvanizing, and play a bit with the wire speed. Also, try adjusting you torch angle. You'll prolly find that one position works better than others. |
terrymason |
Using flux core wire? Problem #1. On galvanized? Problem #2. But it looks like you do have some pen on the larger piece, try grinding off the galvanizing, and play a bit with the wire speed. Also, try adjusting you torch angle. You'll prolly find that one position works better than others. Is flux core bad? My welder doesn't have a tank, so I thought that was my only option. Thanks for the torch angle tip, I hadn't thought about that. |
Lo-Fi Version | Time is now: 4th September 2025 - 06:12 AM |
