What tools do I need?, Another front a arm ? |
bodyman |
May 31 2006, 11:07 PM
Michael Beall Group: Members Posts: 63 Joined: 25-April 06 From: Sand Springs, Oklahoma Member No.: 5,926 |
Ok Everything is loose, Except the front a arm cap and the ball joint. Is the front a arm cap a Allen head? If so what size is it ? also is there a special tool required to get the balljoint loose from the A arm? here are a couple pics of my 2 problem areas.
(IMG:http://i3.tinypic.com/11ay0ds.jpg) (IMG:http://i2.tinypic.com/11ay0l1.jpg) Michael |
914-8 |
May 31 2006, 11:53 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
If you are just trying to get the A-arm off, I'd just disconnect the balljoint from the strut. In other words, you leave the balljoint on the A-arm, unbolt and remove the pin that secures the balljoint to the strut, and pry the balljoint down off the strut.
It's easier, esp, if you don't have the balljoint tool. Removing that balljoint can be tough, because the factory torque spec is something like 180 lb/ft, and without the proper tool, it's hard to get a good enough grip on it. (Also, you should follow the Rule of Removing Stuff - try to remove the hardest and most challenging stuff first, leaving the obvious and easy for last!) |
Lo-Fi Version | Time is now: 10th June 2024 - 07:51 AM |
