nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
seems when i push the engine hard it will suddenly lose power. like it's starving for fuel. doesn't stall but can't get above 2000rpm's or so and it backfires a little. when i take it easier it comes back and runs fine. do fuel pumps get weak or is it a work or not work type of thing. sorry about the typo
BMXerror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 ![]() |
I can't really answer you question about whether a fuel pumkp can get 'weak' or not because I don't know. However, it sounds like you're just getting behind in your fluel flow, as if you don't have the capacity to push it too hard, right? My pop's having the same trouble with his motorcycle right now. I would first check the main feed lines to make sure they're not clogged up as well as the fuel filter. If it turns out not being that or the pump, I might take a look at the enrichment valve. 2000 RPM sounds a little low for it to be needed, but I'm still new to this injection system. I'm just throwing some things out there as if I knew what I was talking about. Don't mind me.
Mark D. Oh yeah... Did this start happening all of the sudden, or has it been a gradual loss? |
Lo-Fi Version | Time is now: 17th June 2024 - 09:32 AM |
