1.7 loses power, furl pump failing? |
nycchef |
Jun 8 2006, 07:43 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
seems when i push the engine hard it will suddenly lose power. like it's starving for fuel. doesn't stall but can't get above 2000rpm's or so and it backfires a little. when i take it easier it comes back and runs fine. do fuel pumps get weak or is it a work or not work type of thing. sorry about the typo
Dr Evil |
Jun 9 2006, 07:11 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Hey Man,
If you can get a fuel pressure tester and hook it up you should check the pressure under load. If when you give it gas you see your pressure drop then that is a sign that your regulator or your pump are kaput (provided your filter and lines are good to go). You do know that there is a filter sock INSIDE the gas tank, right? If it is getting clogged with rust.....well, you get the picture. This is all based on your previous diagnosis of fuel pressure. It could also be a TP sensor or other sensor problem if not FP. |
Lo-Fi Version | Time is now: 17th June 2024 - 06:24 AM |
