Matt Meyer |
Überlurker ![]() ![]() Group: Members Posts: 216 Joined: 2-December 03 From: Eastern Washington Member No.: 1,411 Region Association: Pacific Northwest ![]() |
You guys seem to know everything but I haven’t seen this one yet.
To make a long story short. The problem is almost certainly with the lock cylinder part of ignition. I can start the car by turning the electrical portion of the ignition switch with a screwdriver (steering column torn apart). But with the key (lock cylinder and electrical switch put back together) no start. Assembled, the ignition will turn to on (dash lights up, fuel pump primes) and turns another approx. ?¼? turn, makes a click (relay, not starter solenoid or relay) but no start. I’m not sure if the key needs to turn just a little farther (it feels like it is turning all the way) or if the lock cylinder is too sloppy to turn the switch that last little bit. While trying to figure out a fix last night I thought I observed that the bottom of the ignition switch keyway is spring loaded. It seemed that if the bottom of the keyway was not pushed in the switch would not turn the last 1/8th (no start?). Can someone confirm this? The key when inserted into the ignition does push the lock cylinder key down a small bit. Could my worn non original key just be a tad too short with wear? Maybe the lock cylinder just needs to be in another 1/8” but I don’t see how. More trouble shooting tonight but any help would be appreciated. Also, my 914 is a 75 and I don't think the Pelican tech artical is going to help me get the lock cylinder out. |
jk76.914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States ![]() |
I had the same problem. It was the switch. One of the cheapest jobs on the car.
After almost 4 years, I finally got the interior back in, and the ONLY thing I wasn't going to rebuild on the car was the steering column. And then it happenned to me what happenned to you. So now I have a rebuilt steering column. It wasn't that bad a job- a couple of evenings. Mine's a '76. |
Lo-Fi Version | Time is now: 15th June 2024 - 10:51 AM |
