> Powerless, No power under load
Carlitos Way
post Jun 16 2006, 12:43 PM
I did it MY WAY
I've got a 1.7 block, warmed up to a 2.0 with dual weber carbs. The carbs were jetted per Aircooled.Net specs, and they were just rebuilt by a reputable local carb shop.
When I accelerate, I get absolutely no power. I've replaced the distributor, coil, gas lines, gas pump and made sure the carbs are synchronized.
Car idles like a champ. I can stomp on the gas and it revs up nicely. As soon as I put load to it (i.e. let off the clutch), the car bogs down and sputters.
Any thoughts/ideas?
r_towle
post Jun 16 2006, 01:02 PM
Custom Member
Dirty idle jets.
broken/torn accel pump gasket.
From what I remember (a blatant disclaimer) the main jet does nothing till 2500-3k rpms...something like that...the point being, off the line, you are using the idle jet...and again (memory) there is an additional fuel squirter that shoot fuel in at the top of the venturi...just for take off need...so you get a little extra squirt to go from 0-10 mph...
Look and check the ignition...then look down the carbs (in the venturi) make sure each barrel is squirting the extra fuel...
If the accel gasket os torn, the carbs will still sync up at idle...
If you get stuck...test the carbs at 3000 rpms..
Or ignition.
Rich
Carlitos Way   Powerless   Jun 16 2006, 12:43 PM
So.Cal.914   It still thinks it's a 1.7? Check timing, po...   Jun 16 2006, 12:48 PM
Carlitos Way   Thanks for the quick response. Actually, I forgot...   Jun 16 2006, 01:00 PM
r_towle   Dirty idle jets. broken/torn accel pump gasket. Fr...   Jun 16 2006, 01:02 PM
Toast   Do you have the correct size venturies and/or are ...   Jun 16 2006, 01:09 PM
rhodyguy   carbs...40, 44...? what size are the venturis...   Jun 16 2006, 01:11 PM
ClayPerrine   I would also suggest that you do a "float tes...   Jun 16 2006, 01:16 PM
r_towle   I worked with the aircooled.net guys on a beetle.....   Jun 16 2006, 01:25 PM
rhodyguy   enough with the 009 jokes!! we all know th...   Jun 16 2006, 01:37 PM
obscurity   I had the same thing happen on my 1.7 FI. Turns o...   Jun 16 2006, 01:50 PM
Pompano Beach 914V8   Sure sounds like an ignition problem.   Jun 16 2006, 01:55 PM
Cap'n Krusty   The car should have adequate power, even with the ...   Jun 16 2006, 02:00 PM
Carlitos Way   Cap'n... Assuming I was doing the static timi...   Jun 16 2006, 02:34 PM
Cap'n Krusty
  Jun 19 2006, 02:24 PM
Carlitos Way   Weber 40 mm carbs 32mm venturis F11 Emulsion 52.5...   Jun 19 2006, 03:29 PM
r_towle   I would say..... But this is me..... Idle should b...   Jun 19 2006, 03:48 PM
rhodyguy   i don't see any mention of the timing being ve...   Jun 19 2006, 04:03 PM
scrz914   Just a thought but, are you sure that your brakes ...   Jun 19 2006, 04:06 PM
Joe Sharp   Can you bring the car by my house? :PERMAGRIN: Joe   Jun 19 2006, 04:20 PM
Carlitos Way   If I could bring the car anywhere, I would... I m...   Jun 19 2006, 04:27 PM
Joe Sharp   I time the 009 motors at 27* and forget about idle...   Jun 19 2006, 04:37 PM
Carlitos Way   Thanks for the feedback. I will definitely give t...   Jun 19 2006, 04:38 PM
Carlitos Way   Plugs were somewhat fouled up from when I first tr...   Jun 19 2006, 04:39 PM
Joe Sharp   What plugs are you running? If you've run the ...   Jun 19 2006, 04:55 PM
Howard   Could you limp over to my place?   Jun 19 2006, 04:55 PM
- Lo-Fi Version Time is now: 17th July 2025 - 04:34 AM
