> 1st Gear Grind---help!, Secret to getting in to first gear without grinding gears
2pointOH
post Jun 18 2006, 07:31 AM
Clubbers--
Is it possible that I'm losing lubrication or just my mind?? It seems there are times when getting into 1st gear is simple but lately I can't seem to get back to 1st gear without grinding me and all other stopped traffic to a screeching halt.
I do have a slow drip from under the car--seems I have a slight cack in the bottom transaxel (magnesium) housing which I was told was not repairable?? Could this be the culprit?
I can get into 1st easier once in a while when I push up toward reverse then into first. Sometimes revving up then putting her into 1st helps. Should I be more aggressive or will I slowly chip away at my gearbox???
Any thoughts or tips here?? Any thoughts on costs/sources for parts to repair the lower housing??
Thanks--John
gopack
post Jun 18 2006, 07:35 AM
CHEESEHEAD in CA, MARK
I'm thinking time for a clutch job! that is the symptom I had when I needed a new clutch.
2pointOH   1st Gear Grind---help!   Jun 18 2006, 07:31 AM
gopack   I'm thinking time for a clutch job! that ...   Jun 18 2006, 07:35 AM
914Sixer   Have you checked or replaced all your shifting bus...   Jun 18 2006, 07:47 AM
olav
- Lo-Fi Version Time is now: 15th July 2025 - 04:21 AM
