> 1st Gear Grind---help!, Secret to getting in to first gear without grinding gears
2pointOH
post Jun 18 2006, 07:31 AM
Clubbers--
Is it possible that I'm losing lubrication or just my mind?? It seems there are times when getting into 1st gear is simple but lately I can't seem to get back to 1st gear without grinding me and all other stopped traffic to a screeching halt.
I do have a slow drip from under the car--seems I have a slight cack in the bottom transaxel (magnesium) housing which I was told was not repairable?? Could this be the culprit?
I can get into 1st easier once in a while when I push up toward reverse then into first. Sometimes revving up then putting her into 1st helps. Should I be more aggressive or will I slowly chip away at my gearbox???
Any thoughts or tips here?? Any thoughts on costs/sources for parts to repair the lower housing??
Thanks--John
914Sixer
post Jun 18 2006, 07:47 AM
Have you checked or replaced all your shifting bushings? The plastic bushing behind throwout bearing arm is very critical as is the bushings for the throwout bearing itself. Its the little things that can lead to a clutch job !
2pointOH   1st Gear Grind---help!   Jun 18 2006, 07:31 AM
gopack   I'm thinking time for a clutch job! that ...   Jun 18 2006, 07:35 AM
914Sixer   Have you checked or replaced all your shifting bus...   Jun 18 2006, 07:47 AM
olav
- Lo-Fi Version Time is now: 15th July 2025 - 02:58 AM
