> Getting head temps down, I also need Megasquirt 1.7 STOCK fuelmaps
bd1308
post Jun 19 2006, 06:05 AM
Sir Post-a-lot
So this gets much broader than a drip pan removal.
I need like 20 degrees. I only hit 400 if i am really hard on the car or if i'm on the expressway.
I adjusted the dwell a while back, but I dont remember what I ended up setting dwell AT. I think it wouldnt go past 40 degrees or something, which puzzled me.
See, this all started when I hooked up my new CHT guage. First thing it tells me is that i'm running real hot.....thanks (IMG:style_emoticons/default/headbang.gif)
I'm already building a zero-mile engine, along with a rebuilt 1.7 engine as a spare....
I also would like fuel maps for a stock 1.7 engine...I have a MS computer I am planning to install, and I know someone has the maps for a 1.7 engine somewhere. I will be gutting a laptop and installing it into a centre console for my guage set as well. (IMG:style_emoticons/default/wink.gif)
Engine is a 1.7 engine with *ALL* 1.7 components.
oh and BTW, the sender for the CHT is on cyl #3. I just did a valve adjustment using a tight .007 feeler guage gap.
b
lapuwali
post Jun 19 2006, 04:11 PM
Not another one!
Most CHT gauges (including the VDO) use a thermocouple as the sensor. Thermocouples generate a voltage based on the difference in temperature between the two ends of thermocouple wire (any pair of dissimilar metals will do, but certain metals are used for calibration purposes). The "reference" temp (the "cold" end) for the VDO is assumed to be 70dF. So, the gauge shows the difference between the "hot" end (at the plug) and whatever temp the "cold" end sees, adjusted so a 70dF "cold" end shows 0dF on the gauge.
So, if it's colder than 70dF, the sensor will see a larger difference for the same head temp, so the gauge will read high. If it's hotter, the gauge reads low.
Dakota Digital makes a (much more expensive) gauge that's compensated for ambient temp differences, using thermistor to measure ambient temps.
They don't use thermistors for most head temp sensors, as themistors tend to flake out beyond 250dF or thereabouts. The stock D-Jet CHT is a thermistor, but it's positioned in the head to top out at roughly 220dF, and it's only measuring temps colder than this, anyway (warm-up sensor). Thermocouples have higher and wider temp ranges, are generally more accurate, and typically react faster, than thermistors. However, they also generate very small voltages (0.1-0.5 mV), and very small differences make a big difference to the measured temp. I think the difference between 300dF and 500dF is under 0.2mV. So, you need an accurate, non-distorting amplifier, or a very sensitive gauge movement, to use them. This is why the CHT gauges are all over $100, where a water temp gauge is under $40.
If it's 90dF outside, add 20dF to what the gauge shows to get the actual head temp. If it's 50dF outside, subtract 20dF.
I have no idea how accurate the VDO gauge actually is, and I'd doubt if it's much better than 10dF. Unless it's blazing hot out, or freezing cold, I'd not worry much about the ambient temp variance.
From what data I've been able to glean from Jake, a stock D-Jet engine will NORMALLY see 375dF or thereabouts under load, with spikes to 405 or so if you're climbing a grade. This has to do with a head and cam design more optimized for emissions than cool running or power.
bd1308   Getting head temps down   Jun 19 2006, 06:05 AM
Bleyseng   Is it a VDO CHT gauge? Is it set for the outside t...   Jun 19 2006, 09:26 AM
Brett W   Too far advanced timing will not raise head temps....   Jun 19 2006, 11:54 AM
bd1308   I run premium fuel, due to the high compression of...   Jun 19 2006, 01:30 PM
lapuwali   Which year is the 1.7, and is it still stock? The...   Jun 19 2006, 01:38 PM
Bleyseng   I thought that spec was for Calif only 1.7L. The r...   Jun 19 2006, 01:54 PM
bd1308   its a EB engine I think. It had the 1973 only pap...   Jun 19 2006, 02:49 PM
r_towle   Slow down. Do the proper engineering diagnostics w...   Jun 19 2006, 03:05 PM
Mueller   PM Fiid, he might still have the config setting fr...   Jun 19 2006, 03:26 PM
Brett W   Compression ratio is not that high. Run it on 87 ...   Jun 19 2006, 03:57 PM
lapuwali   Most CHT gauges (including the VDO) use a thermoco...   Jun 19 2006, 04:11 PM
bd1308   the new engine I am planning to build will contain...   Jun 20 2006, 01:58 AM
Mueller
- Lo-Fi Version Time is now: 17th July 2025 - 04:59 AM
