> Powerless, No power under load
Carlitos Way
post Jun 16 2006, 12:43 PM
I did it MY WAY
I've got a 1.7 block, warmed up to a 2.0 with dual weber carbs. The carbs were jetted per Aircooled.Net specs, and they were just rebuilt by a reputable local carb shop.
When I accelerate, I get absolutely no power. I've replaced the distributor, coil, gas lines, gas pump and made sure the carbs are synchronized.
Car idles like a champ. I can stomp on the gas and it revs up nicely. As soon as I put load to it (i.e. let off the clutch), the car bogs down and sputters.
Any thoughts/ideas?
Carlitos Way
post Jun 19 2006, 04:39 PM
I did it MY WAY
Plugs were somewhat fouled up from when I first tried to run the car (one Carb was definitely phuked up! So now that the plugs are new, it's hard to get a read on them yet.
Carlitos Way   Powerless   Jun 16 2006, 12:43 PM
So.Cal.914   It still thinks it's a 1.7? Check timing, po...   Jun 16 2006, 12:48 PM
Carlitos Way   Thanks for the quick response. Actually, I forgot...   Jun 16 2006, 01:00 PM
r_towle   Dirty idle jets. broken/torn accel pump gasket. Fr...   Jun 16 2006, 01:02 PM
Toast   Do you have the correct size venturies and/or are ...   Jun 16 2006, 01:09 PM
rhodyguy   carbs...40, 44...? what size are the venturis...   Jun 16 2006, 01:11 PM
ClayPerrine   I would also suggest that you do a "float tes...   Jun 16 2006, 01:16 PM
r_towle   I worked with the aircooled.net guys on a beetle.....   Jun 16 2006, 01:25 PM
rhodyguy   enough with the 009 jokes!! we all know th...   Jun 16 2006, 01:37 PM
obscurity   I had the same thing happen on my 1.7 FI. Turns o...   Jun 16 2006, 01:50 PM
Pompano Beach 914V8   Sure sounds like an ignition problem.   Jun 16 2006, 01:55 PM
Cap'n Krusty   The car should have adequate power, even with the ...   Jun 16 2006, 02:00 PM
Carlitos Way   Cap'n... Assuming I was doing the static timi...   Jun 16 2006, 02:34 PM
Cap'n Krusty
  Jun 19 2006, 02:24 PM
Carlitos Way   Weber 40 mm carbs 32mm venturis F11 Emulsion 52.5...   Jun 19 2006, 03:29 PM
r_towle   I would say..... But this is me..... Idle should b...   Jun 19 2006, 03:48 PM
rhodyguy   i don't see any mention of the timing being ve...   Jun 19 2006, 04:03 PM
scrz914   Just a thought but, are you sure that your brakes ...   Jun 19 2006, 04:06 PM
Joe Sharp   Can you bring the car by my house? :PERMAGRIN: Joe   Jun 19 2006, 04:20 PM
Carlitos Way   If I could bring the car anywhere, I would... I m...   Jun 19 2006, 04:27 PM
Joe Sharp   I time the 009 motors at 27* and forget about idle...   Jun 19 2006, 04:37 PM
Carlitos Way   Thanks for the feedback. I will definitely give t...   Jun 19 2006, 04:38 PM
Carlitos Way   Plugs were somewhat fouled up from when I first tr...   Jun 19 2006, 04:39 PM
Joe Sharp   What plugs are you running? If you've run the ...   Jun 19 2006, 04:55 PM
Howard   Could you limp over to my place?   Jun 19 2006, 04:55 PM
- Lo-Fi Version Time is now: 17th July 2025 - 05:17 AM
