> Info needed on cable shift 901, Someone splain to me in Big Bird terms
mrdezyne
post Jun 21 2006, 10:14 AM
Now on larger rolling jack stands!
Lots of good info out there on cable shifters for the 901 and 930 transaxles. I've been trying to keep up with most of them, but I'm having trouble visualizing what has to happen at the tail end of a side shift 901. I've seen several brackets and how the cables are connected but I still don't have a clear picture. Can someone in the know help provide a little insight? Please use small words and lots of pictures.... (IMG:style_emoticons/default/blink.gif)
Let cable shift 101 begin....
TonyAKAVW
post Jun 21 2006, 10:36 AM
That's my ride.
In this picture (my prototype shifter) you can see there are two threaded rods. These threaded rods are where the cable ends attach. The one in the distance at the top is for the rotational motion. If you pull or push that lever left or right it will rotate the shaft (which is going straight down through the aluminum plate into the transmission).
The other motion is accomplished by pushing or pulling the threaded rod that has the two nuts on it. If that is pushed left or right it forces the white plastic block to move up and down. That forces the selector to pull out or push into the transmission.
In the second picture you can see thethreaded rod that in the first picture is at the top, and kind of blurry.
Sorry for the SirAndy style photo (IMG:style_emoticons/default/smile.gif)
-Tony
mrdezyne   Info needed on cable shift 901   Jun 21 2006, 10:14 AM
Jeroen   :popcorn:   Jun 21 2006, 10:21 AM
TonyAKAVW   There are two movements that need to happen. The ...   Jun 21 2006, 10:28 AM
Dave_Darling   You need two cables, both of which are push-pull c...   Jun 21 2006, 10:34 AM
TonyAKAVW   In this picture (my prototype shifter) you can see...   Jun 21 2006, 10:36 AM
mrdezyne   So the brass bearing is supposed to be attached to...   Jun 21 2006, 10:47 AM
TonyAKAVW
- Lo-Fi Version Time is now: 13th July 2025 - 08:17 PM
