Joseph Mills |
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 ![]() |
My 914 goes to the shop next week for alignment: 1.5 to 2 degrees neg camber front, 2 to 2.5 neg rear with 1/16" toe-out front, 1/16" toe-in rear. Tires are Hoosier A3S03's.
I have found a few posts that seem to indicate that when the A-arms and trailing arms are parallel to the ground, you have maximized your cars height. Is this in fact, correct? If so, why is this level preferred? If you go below this height is suspension geometry adversely effected? How much wheel travel is left at this point? Joseph '75 914 2.0L AX bound |
drew365 |
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 ![]() |
J.P.; No shims were used in the rear. He corner balanced the car so I assume he balanced the need for good corner balance and more negative camber.
Joseph; I'm setting the car up for track only. It really only gets driven on the street to and from the shop. Brad; Thanks for the info, I'm not Ricky Racer yet but I'm turning respectable times and think I get the tires up to temp. |
Lo-Fi Version | Time is now: 23rd September 2025 - 04:17 AM |
