Midtowner |
Ooooo! ![]() ![]() ![]() Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None ![]() |
I'm betting someone here has an answer. The Car: '73 2.0, 90,000 miles. 19mm master cylinder. Brake proportioning valve. New Zimmerman rotors and Ferodo pads front and rear. New inner and outer front bearings. New fluid. All parts installed by reputable shop in Silicon Valley. Master Cylinder not leaking. The Problem: Pedal pressure only results in gliding to a stop. Unable to lock the wheels.
Any ideas what's going on? (IMG:style_emoticons/default/huh.gif) |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Speed bleeders solve the bleeding issues and make it easy to pump a pint of fluid thru to get rid of the air bubbles in the prop. valve.
When you do this, stomp on the petal a few times then bleed em. |
Lo-Fi Version | Time is now: 14th July 2025 - 04:26 AM |
