> No Significant Brake Pressure, Brake Experts Chime In
Midtowner
post Jun 26 2006, 10:44 PM
Ooooo!
I'm betting someone here has an answer. The Car: '73 2.0, 90,000 miles. 19mm master cylinder. Brake proportioning valve. New Zimmerman rotors and Ferodo pads front and rear. New inner and outer front bearings. New fluid. All parts installed by reputable shop in Silicon Valley. Master Cylinder not leaking. The Problem: Pedal pressure only results in gliding to a stop. Unable to lock the wheels.
Any ideas what's going on? (IMG:style_emoticons/default/huh.gif)
Dr. Roger
post Jun 27 2006, 12:54 AM
A bat out of hell.
is your pedal firm or does it go to the floor? i hate to assume anything...
have you properly bedded in the pads?
frodo's, what type? race or street?
Midtowner   No Significant Brake Pressure   Jun 26 2006, 10:44 PM
Dan (Almaden Valley)   Air in proportioning valve, Erik. Bleed, bleed an...   Jun 26 2006, 10:56 PM
Dan (Almaden Valley)   Erik, After the shop did the work, didn't th...   Jun 26 2006, 11:18 PM
bd1308   mine glides to a stop too... lol but my rear R r...   Jun 26 2006, 11:19 PM
Bleyseng   Speed bleeders solve the bleeding issues and make ...   Jun 26 2006, 11:24 PM
So.Cal.914   If everything is new and tight than it is air, unl...   Jun 27 2006, 12:20 AM
jk76.914   We're all assuming air in the system, but you ...   Jun 27 2006, 12:45 AM
Dr. Roger   is your pedal firm or does it go to the floor? i ...   Jun 27 2006, 12:54 AM
Midtowner   See? I knew someone would have the answer here...   Jun 27 2006, 10:18 AM
jk76.914
- Lo-Fi Version Time is now: 14th July 2025 - 04:21 AM
