Midtowner |
Ooooo! ![]() ![]() ![]() Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None ![]() |
I'm betting someone here has an answer. The Car: '73 2.0, 90,000 miles. 19mm master cylinder. Brake proportioning valve. New Zimmerman rotors and Ferodo pads front and rear. New inner and outer front bearings. New fluid. All parts installed by reputable shop in Silicon Valley. Master Cylinder not leaking. The Problem: Pedal pressure only results in gliding to a stop. Unable to lock the wheels.
Any ideas what's going on? (IMG:style_emoticons/default/huh.gif) |
Midtowner |
See? I knew someone would have the answer here! Perhaps I can answer a few questions.
1) Brake issue was discovered during a road test by the shop. Car is still there. 2) Caliper pistons are probably stuck. Never thought of that one but it is very possible given that the car was sitting in a garage for sixteen years. 3) Ferodo pads for street. Thanks a bunch. I'm calling the shop now. This place rocks. (IMG:style_emoticons/default/biggrin.gif) |
jk76.914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States ![]() |
See? I knew someone would have the answer here! Perhaps I can answer a few questions. 1) Brake issue was discovered during a road test by the shop. Car is still there. 2) Caliper pistons are probably stuck. Never thought of that one but it is very possible given that the car was sitting in a garage for sixteen years. 3) Ferodo pads for street. Thanks a bunch. I'm calling the shop now. This place rocks. (IMG:style_emoticons/default/biggrin.gif) 16 years? Yeah, calipers are probably corroded inside due to moisture in the fluid. Make sure these guys know what they're doing before you let them take apart the rears. There are lots of pointers on this site to shops who know how to rebuild/restore/refurb these things. After waiting 16 years, another couple of weeks of turnaround isn't going to hurt anything. Good luck! |
Lo-Fi Version | Time is now: 14th July 2025 - 04:01 AM |
