> Timing fun!, Engine runs 50 degrees hotter!
sportlicherFahrer
post Jun 27 2006, 03:30 AM
Nothing to see here.
Having fun with my engine right now. Went to a Blaster 2 coil and WAS running Petronix. Guy at FLAPS told me I dont need a resistor inline with the coil. 30 minutes after the install, *poof* no spark. Figured out that the Petronix was dead by the smell coming from the dizzy. So I backdate to points on the side of the road and add a resistor. I got the gap nice and close, and set the timing by ear. Car reads a lot hotter on the oil temp guage now. So I check the dwell angle and timing. Dwell is at about 50 deg. at idle BUT goes down to about 40 at higher rpm. I proceed to check timing. Set it at 27 deg. and let the car return to idle and it dies. I gave the dizzy a nudge to advance it just a bit, start it back up and it idles LOW. Has NO bottom end power, and has about 1500rpm of power up high. If I give it any more advance, it pings. I am running good gas, so its not that. Still runs really hot. About 240deg on the oil temp, where it was reading about 180-190deg. before. I am really trying to figure out why I cant get it to run good now! Anything I should check out? I have checked the basics, but its not working!
SIDENOTE
My car ran like a bat outta hell before I went to the blaster coil. Ran even better with that in there until the Petronix burned up. It isnt my FI at all as far as I know. I had a really good idle quality, and great power all the way up to 5500rpm.
(IMG:style_emoticons/default/WTF.gif) is going on????
T wing
post Jun 27 2006, 11:50 AM
yes, my car is normally this dirty
Wow, I just saw the time of that first post. You sleep like I do.
Joe Ricard
post Jun 27 2006, 02:48 PM
CUMONIWANNARACEU
QUOTE(T wing @ Jun 27 2006, 12:50 PM) *
Hell I had already been at work for nearly 2 hours. and I STILL have an hour to go. (IMG:style_emoticons/default/owned.gif)
sportlicherFahrer   Timing fun!   Jun 27 2006, 03:30 AM
Joe Ricard   Go to FLAPS and beat the piss out of the guy. Dwel...   Jun 27 2006, 05:42 AM
Rand   You'll get those exact symptoms (no bottom end...   Jun 27 2006, 10:31 AM
T wing   Hey, if you still need a dwell/tach and timing lig...   Jun 27 2006, 11:49 AM
T wing   Wow, I just saw the time of that first post. You ...   Jun 27 2006, 11:50 AM
Joe Ricard
- Lo-Fi Version Time is now: 7th July 2025 - 06:01 AM
