Carb guru's I need your help, Break out the black magic book I'm stumped |
Joe Ricard |
Jun 28 2006, 05:20 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Car has been progressively getting worse.
the problem is off idle stumble. I have to date pulled carbs cleaned out everything. Rechecked and slightly adjusted floats 10mm. Tweaked on accelerator pump linkage (no change). Went down idle jet made it worse 53 to 50. Went up to 55 idle now it sort of covers up the problem but still stumbles. Checked timing Mallory dizzy. bumped it up about a degree (slightly bettter) but still stumbles. 2.0L 86b cam Tangerine 40 IDF's 32mm vents. Runs like a scaulded dog on main jets. Also spent 1/2 hour synching up carb linkage (perfect) off idle. still stumbles. So I am out of tricks. What am I missing. (IMG:style_emoticons/default/blink.gif) Oh yea valves are set good too. good plug wires good plugs. |
J P Stein |
Jun 28 2006, 05:35 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
You gots MSD?
Joe Ricard |
Jun 28 2006, 05:43 AM
You gots MSD? Had a Mallory Hyfire but that took a shit 6 months ago. Running the Mallory Dizzy with Mallory Pro E coil and inline Resistor. Hmmm Might just put a Bosch Blue coil on it and see what it does. Good call. (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 05:33 PM |
