> Fuel lines, Return line for carbs
spunone
post Jun 27 2006, 06:55 PM
Installed some 3/8 stainless fuel lines both feed & return.Now after talking to A guy from Aeromotive return line is not big enough if I use there's or mallorys return regulators .Said line not big enough on the return and will flood carbs at Idle (IMG:style_emoticons/default/WTF.gif) Anybody have any ideas .? Besides putting in larger return Line .Thanks
tat2dphreak
post Jun 28 2006, 03:29 PM
stoya, stoya, stoya
now I'm really confused... carbs generally like warmer fuel than FI, so using the return line to cool the fuel seems counter productive..
how is the setup properly plumbed though? there's not return-out for webers that I've ever seen...
as it is now:
fuel line from tank
________________________________========carb 1
________________________________||
(tank)=(pump)==============="T"
________________________________========carb 2
spunone   Fuel lines   Jun 27 2006, 06:55 PM
Thack   Use a small fuel pump to feed back into the gas ta...   Jun 27 2006, 07:18 PM
URY914   Let me get this right. You have 3/8" supply...   Jun 27 2006, 07:23 PM
Thack   Why do you need a return regulator? Is the flow th...   Jun 27 2006, 07:27 PM
GeorgeRud   As long as there's a return and a fuel pressur...   Jun 27 2006, 07:34 PM
lapuwali   Note he said their or Mallory's return regulat...   Jun 27 2006, 07:55 PM
spunone   he said supply line is fine but with a return smal...   Jun 27 2006, 09:17 PM
tat2dphreak   umm... carbs don't use a return line.. .at lea...   Jun 27 2006, 09:24 PM
Aaron Cox   carbs DO use a return line... if you do it the UBE...   Jun 27 2006, 09:31 PM
brant   Thanks for the introduction Aaron... yep.. I'm...   Jun 27 2006, 10:16 PM
Thack   Unless you have a monster motor, this Mallory unit...   Jun 27 2006, 10:19 PM
spunone   I'm going to be running a 2316 about a 185 HP...   Jun 28 2006, 07:29 AM
brant   I'm just running a holley regulator (not too i...   Jun 28 2006, 08:19 AM
tat2dphreak   now I'm really confused... carbs generally lik...   Jun 28 2006, 03:29 PM
spunone   Ok Wayne here ya go Tank- Filter -Pump - regulato...   Jun 28 2006, 03:34 PM
tat2dphreak   ok, I see... my regulator is at the "T" ...   Jun 28 2006, 03:39 PM
scottb   any one have a part number and dealer for a return...   Jun 28 2006, 04:09 PM
brant   Ok... I finally found the old thread I wanted on t...   Jun 28 2006, 04:30 PM
spunone   Mallory makes a nice regulator with return as does...   Jun 28 2006, 05:01 PM
Thack   I see what you mean now. Are you going to replace ...   Jun 28 2006, 05:13 PM
spunone   Well I'm going to punch a hole in the top of ...   Jun 28 2006, 05:20 PM
Racer Chris   I can make a 1/2" line for the tunnel Paul. I...   Jun 28 2006, 09:20 PM
URY914   Chris, do you run a return line on your car? P   Jun 29 2006, 07:07 AM
Racer Chris   I have never used a return line with carbs. I gues...   Jun 29 2006, 07:54 AM
- Lo-Fi Version Time is now: 11th July 2025 - 11:51 AM
