> Fuel lines, Return line for carbs
spunone
post Jun 27 2006, 06:55 PM
Installed some 3/8 stainless fuel lines both feed & return.Now after talking to A guy from Aeromotive return line is not big enough if I use there's or mallorys return regulators .Said line not big enough on the return and will flood carbs at Idle (IMG:style_emoticons/default/WTF.gif) Anybody have any ideas .? Besides putting in larger return Line .Thanks
spunone
post Jun 28 2006, 05:20 PM
Well I'm going to punch a hole in the top of the gas tank put in a bulk head an 8 fitting and run a new 1/2 " return why not was else is new . Seems every time I start to do something I redo 3 times before I get it done (IMG:style_emoticons/default/sheeplove.gif)
spunone   Fuel lines   Jun 27 2006, 06:55 PM
Thack   Use a small fuel pump to feed back into the gas ta...   Jun 27 2006, 07:18 PM
URY914   Let me get this right. You have 3/8" supply...   Jun 27 2006, 07:23 PM
Thack   Why do you need a return regulator? Is the flow th...   Jun 27 2006, 07:27 PM
GeorgeRud   As long as there's a return and a fuel pressur...   Jun 27 2006, 07:34 PM
lapuwali   Note he said their or Mallory's return regulat...   Jun 27 2006, 07:55 PM
spunone   he said supply line is fine but with a return smal...   Jun 27 2006, 09:17 PM
tat2dphreak   umm... carbs don't use a return line.. .at lea...   Jun 27 2006, 09:24 PM
Aaron Cox   carbs DO use a return line... if you do it the UBE...   Jun 27 2006, 09:31 PM
brant   Thanks for the introduction Aaron... yep.. I'm...   Jun 27 2006, 10:16 PM
Thack   Unless you have a monster motor, this Mallory unit...   Jun 27 2006, 10:19 PM
spunone   I'm going to be running a 2316 about a 185 HP...   Jun 28 2006, 07:29 AM
brant   I'm just running a holley regulator (not too i...   Jun 28 2006, 08:19 AM
tat2dphreak   now I'm really confused... carbs generally lik...   Jun 28 2006, 03:29 PM
spunone   Ok Wayne here ya go Tank- Filter -Pump - regulato...   Jun 28 2006, 03:34 PM
tat2dphreak   ok, I see... my regulator is at the "T" ...   Jun 28 2006, 03:39 PM
scottb   any one have a part number and dealer for a return...   Jun 28 2006, 04:09 PM
brant   Ok... I finally found the old thread I wanted on t...   Jun 28 2006, 04:30 PM
spunone   Mallory makes a nice regulator with return as does...   Jun 28 2006, 05:01 PM
Thack   I see what you mean now. Are you going to replace ...   Jun 28 2006, 05:13 PM
spunone   Well I'm going to punch a hole in the top of ...   Jun 28 2006, 05:20 PM
Racer Chris   I can make a 1/2" line for the tunnel Paul. I...   Jun 28 2006, 09:20 PM
URY914   Chris, do you run a return line on your car? P   Jun 29 2006, 07:07 AM
Racer Chris   I have never used a return line with carbs. I gues...   Jun 29 2006, 07:54 AM
- Lo-Fi Version Time is now: 11th July 2025 - 06:56 AM
