| kskwpb |
Jul 2 2006, 12:57 PM
Newbie ![]() Group: Members Posts: 20 Joined: 30-May 06 From: West Palm Beach Member No.: 6,098 |
Well, here's a shocker....You guys were totally right on with my fuel pump nightmare, pulled the relay board, Big chunk missing under large three prong relay? Well I sodered the connector, busted out glue gun,filled in relay board....put it in...fuel pump purred like a kitten....now NO Spark @ plugs or when I pull wire from coil to distributor cap....It's like the ignition is turned off....Help me...PLEASE (IMG:style_emoticons/default/unsure.gif) Best Regards & CHEERS to all. Kevin
| So.Cal.914 |
Jul 2 2006, 01:51 PM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Do you own a meter? If not try a hot wire from battery to heat ignition if still
no spark you know it is eather coil or points/ EI. |
| kskwpb |
Jul 2 2006, 02:03 PM
kskwpb No Spark...(76 2.0 FI)Shoot Me...PLEASE! Jul 2 2006, 12:57 PM
kskwpb ![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2026 - 06:00 AM |
