Almost no airflow through Unisyn - what's this mean? |
smontanaro |
Jul 4 2006, 12:09 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
My /6 (original 2.0L) idles kinda rich. I decided I'd see if I could do something about it today. Got out my trusty Unisyn and my 8mm wrench. The instructions I have said to set the Unisyn based on the left rear (#6) throat and adjust it so the red ball is about halfway up the tube. Alas, I had to screw the adjuster in almost all the way to get the ball to move at all and the engine didn't stumble at all. I messed with the idle air screw to get it up to the first line (still with the Unisyn's adjuster nearly fully closed). The other throats all seemed to flow enough air to pick the ball up easily, and the obstruction caused by the Unisyn caused the engine to stumble at idle.
That suggests to me that there's something fishy w/ #6. What does it suggest to the experts among you? (IMG:style_emoticons/default/confused24.gif) (Non-experts with wild-ass guesses are welcome to chime in as well... (IMG:style_emoticons/default/biggrin.gif)) Thx, Skip |
IronHillRestorations |
Jul 5 2006, 07:56 AM
I. I. R. C. Group: Members Posts: 6,728 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd pitch the Unisyn and get a STE. STE airflow meters do not restrict airflow, like a Unisyn, and give a much more accurate measurement.
This doesn't solve your problem though. Make sure you've got spark, fuel, compression in the cylinder that isn't pulling. You may also need a valve adjustment. Regarding valve adjustments, a little loose isn't OK or better than a little tight, dead nuts is what you want. |
Aaron Cox |
Jul 5 2006, 11:00 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
I'd pitch the Unisyn and get a STE. STE airflow meters do not restrict airflow, like a Unisyn, and give a much more accurate measurement. This doesn't solve your problem though. Make sure you've got spark, fuel, compression in the cylinder that isn't pulling. You may also need a valve adjustment. Regarding valve adjustments, a little loose isn't OK or better than a little tight, dead nuts is what you want. couldnt agree more. the snail ones are a ton better than the ball in the tube..... i can get you one locally for about 25 bucks... vs everywhere else on the net for 40.... AA |
Lo-Fi Version | Time is now: 6th June 2024 - 06:45 PM |
