DOT5. What does it do to regular brake seals, etc?, Do you need anything special to use it? |
RoadGlue |
Jul 7 2006, 01:15 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
I ask, because my recently aquired 914 has DOT 5 brake fluid, but I don't know what, if any provisions have been made to the car to use it. I know a rear caliper was recently replaced with an off the shelf used caliper with stock seals.
I'd like to go back to using Super Blue. Is a flush in order, or would I be looking at a complete brake system overhaul? Thanks! |
lapuwali |
Jul 7 2006, 02:02 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
It's 5.1, not 5.2. DOT5 is silicone-based fluid. DOT5.1 is not.
I pretty much agree with Dave. Any silicone fluid in the system will react badly with non-silicone fluid, making this whitish goo that likes to ball up and block passages. You might try draining a sample from the system into a cup, and add some of your favorite fluid, to see what happens. |
RoadGlue |
Jul 7 2006, 02:40 PM
It's 5.1, not 5.2. DOT5 is silicone-based fluid. DOT5.1 is not. I pretty much agree with Dave. Any silicone fluid in the system will react badly with non-silicone fluid, making this whitish goo that likes to ball up and block passages. You might try draining a sample from the system into a cup, and add some of your favorite fluid, to see what happens. Sorry, I should have been clearer. I've been told that the car has silicone fluid in it now. I'd like to ditch that and go with ATE's 5.1 (right?) as I have two full, unopened containers sitting on my garage's floor. I'll see how the two react, good suggestion. So what do I do if they react poorly? Power flush? Thank a lot! |
Lo-Fi Version | Time is now: 31st May 2024 - 08:52 PM |
