Sorry but need Help with Valve covers |
Kerrys914 |
Oct 10 2003, 06:44 AM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
I have taken my dam valve cover off 3 times to fix this leak, with no luck.
I had a what I thought was rocker tap so I took off my 0% leaking valve cover to inspect things. Everything was fine so I reinstalled the cover and went about my other duties......the next thing I know......Smoke every where and oil sizzle'n on the heat exchanger. I think it is coming from the top/rear part of the cover. I can see signs of oil on the rear side of the head near the cover. During the last install (number 3) I cleaned both surfaces very well and used permatex on the cover to hold the gasket on. I waited about 30-45 mins and installed the cover onto the head. Nothing betweeen the gasket and the head (this seemed to be what most were/are doing). In less then 5 mins drip drip drip SMOKE... I am loving it (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) I even took the heatexchanger off last time to make sure I could get full access to the head. I am now at the point I think I will use permatex on the head as well AND thinking about the P Parts fix using sheet metal strips welded to the inside of the cover. Does this work? Anyone have a set available? Could there be any engine pressure issues that could cause oil leaks like this. It is a steady drip one every second...? (IMG:style_emoticons/default/ohmy.gif) Cheers Kerry (IMG:style_emoticons/default/beer.gif) |
Brad Roberts |
Oct 10 2003, 11:39 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I gotcha. Not sure when John wrote that. We sell a brand new VW cover with these welded in (does no good to weld the strips to a bent cover.)
B |
Lo-Fi Version | Time is now: 9th June 2024 - 11:13 PM |
