Teknon |
The more I learn the dumber i think I am ![]() ![]() Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains ![]() |
It's probably been said before many times. So if there is a thread you can lead me too all well and good. (IMG:style_emoticons/default/confused24.gif)
I am having a 2270 built and was told the DJet FI will not be enough to handle the fuel requirement of this engine. I am not interested in a mechanical carburetor at all. And have no room for that discussion. (IMG:style_emoticons/default/dead horse.gif) Why can’t the DJet keep up? Can it be tweaked or larger injectors installed? (IMG:style_emoticons/default/WTF.gif) “Chicken Little” type members need not answer, as I don’t need someone’s emotional opinion. What I would like is a down to earth technical understanding. (IMG:style_emoticons/default/yappin.gif) I am surprised no one made a daughter board to augment the existing ECU to test oxygen or whatever would be pertinent. Thanks for your time and experience. Joe D2 |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Part of the problem is the cam, so what cam are you using?? Even a Web73 is a pain to tune due to the valve overlap to get a good idle.
Far as I can tell there should be plenty of fuel delivery even for a 2270. I should try a test on DaveHunts 2270 and stick back on the Djet parts and tune just to get a baseline MPS. I have pretty much go my 2056 with a Raby 9550 (web73) set up and it rocks! Well, Dave ya wanna try???? The problem with Djet tuning is you have 3 thats it , 3 tuning tools, idle, partload and WOT. Its a lot of trial and error to get them set up right using a wideband O2 sensor. You don't need a O2 after you set it up as it is hard wired then. RichD, did you repair the exhaust leaks yet so we can tune yours. |
Lo-Fi Version | Time is now: 1st July 2025 - 09:45 AM |
