Teknon |
The more I learn the dumber i think I am ![]() ![]() Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains ![]() |
It's probably been said before many times. So if there is a thread you can lead me too all well and good. (IMG:style_emoticons/default/confused24.gif)
I am having a 2270 built and was told the DJet FI will not be enough to handle the fuel requirement of this engine. I am not interested in a mechanical carburetor at all. And have no room for that discussion. (IMG:style_emoticons/default/dead horse.gif) Why can’t the DJet keep up? Can it be tweaked or larger injectors installed? (IMG:style_emoticons/default/WTF.gif) “Chicken Little” type members need not answer, as I don’t need someone’s emotional opinion. What I would like is a down to earth technical understanding. (IMG:style_emoticons/default/yappin.gif) I am surprised no one made a daughter board to augment the existing ECU to test oxygen or whatever would be pertinent. Thanks for your time and experience. Joe D2 |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
I agree with James with regard to the sizing of the intake setup.
I also agree that the fuel delivery system is not a limitation as far as being able to deliver enough fuel for the 2270 or larger. But d-jet requires a mild cam to function properly because it is dependent on manifold pressure. An agressive cam disrupts this. So you would need to use a very mild cam with your 2270. But why are you building a 2270? More power right? So why would you cripple your motor with a mild cam? You wouldn't. Which is why d-jet is a bad choice. It's like putting a 3.2L six into your car but keeping the stock 165 width tires. Sure, you can do it, but it makes no sense. Demick |
Lo-Fi Version | Time is now: 1st July 2025 - 02:10 PM |
