> Tire temps, For you track driver/racer types
campbellcj
post Feb 28 2003, 10:06 PM
I can't Re Member
OK, I know that the general concept of tire temps (pyrometer reading) is you want to check your alignment and suspension setup by looking for even or "logical" temps across the tread of the tire (outside, middle, inside) and also from front-rear and side-side.
Is there good detailed write-up somewhere explaining what different flavors of temp readings mean and what to do about it (corrective action)?
Also, what is considered a good operating temp for typical DOT-R tires like Kumhos? If your tires are "cold" or "hot" compared to what is the desirable range, what does that really mean (corrective action)? In other words if I have even temps, but low 100's instead of upper 100's or low 200's, does that mean I should just push harder in the turns, or what?
Mildly Confused,
drew365
post Feb 28 2003, 10:32 PM
These are the good old days!
Chris; try www.elephantracing.com/techtopic/tiretemp.htm
They have a basic symptom/diagnosis chart thats helpful. I've been told 180o is a normal track temp. 200 is too hot.
- Lo-Fi Version Time is now: 3rd July 2025 - 11:44 PM
