tiim5 |
Member ![]() ![]() Group: Members Posts: 86 Joined: 13-March 04 From: Menlo Park CA Member No.: 1,791 ![]() |
The recent heat wave in the bay area caused me to wonder if there are methods to 'cool' or otherwise lower the temperature of our engines while we are driving?
I recall an article in Hot Rod magazine years ago, suggesting coasting in neutral, preferably downhill, as a method to cool a V8 engine. The engine at idle slows the pumping of coolant allowing more time to cool in the radiator. When you would put it back in gear the colder coolant would enter the block and the temperature drop was noticable. I assume at idle our engines fans are least efficient but at higher rpm more air is moved but operating temp should also increase making this a wash? Is there anything one can do to get the temp to drop? Is driving at a constant speed, 70 mph for example better than varying speeds? If the engine gets hot is there any way to cool it down while driving? Thanks |
lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
The methods I know of are:
External oil cooler with fresh air flow. Fresh air flow into engine compartment from outside. Someone did a measurment of negative pressures at the engine grill and in the compartment and under the engine. It seem that there was little gradient for flows. Additionally, I removed every other or kept every third fan blade, which is supposed to improve flow. Additionally, there is the DTM down the middle modification that can be done. Larry |
Lo-Fi Version | Time is now: 4th July 2025 - 11:45 AM |
