tiim5 |
Member ![]() ![]() Group: Members Posts: 86 Joined: 13-March 04 From: Menlo Park CA Member No.: 1,791 ![]() |
The recent heat wave in the bay area caused me to wonder if there are methods to 'cool' or otherwise lower the temperature of our engines while we are driving?
I recall an article in Hot Rod magazine years ago, suggesting coasting in neutral, preferably downhill, as a method to cool a V8 engine. The engine at idle slows the pumping of coolant allowing more time to cool in the radiator. When you would put it back in gear the colder coolant would enter the block and the temperature drop was noticable. I assume at idle our engines fans are least efficient but at higher rpm more air is moved but operating temp should also increase making this a wash? Is there anything one can do to get the temp to drop? Is driving at a constant speed, 70 mph for example better than varying speeds? If the engine gets hot is there any way to cool it down while driving? Thanks |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,009 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
how come no one has yet mentioned the most important cooling tool of all?
Jack stands |
Lo-Fi Version | Time is now: 4th July 2025 - 09:18 PM |
