tiim5 |
Member ![]() ![]() Group: Members Posts: 86 Joined: 13-March 04 From: Menlo Park CA Member No.: 1,791 ![]() |
The recent heat wave in the bay area caused me to wonder if there are methods to 'cool' or otherwise lower the temperature of our engines while we are driving?
I recall an article in Hot Rod magazine years ago, suggesting coasting in neutral, preferably downhill, as a method to cool a V8 engine. The engine at idle slows the pumping of coolant allowing more time to cool in the radiator. When you would put it back in gear the colder coolant would enter the block and the temperature drop was noticable. I assume at idle our engines fans are least efficient but at higher rpm more air is moved but operating temp should also increase making this a wash? Is there anything one can do to get the temp to drop? Is driving at a constant speed, 70 mph for example better than varying speeds? If the engine gets hot is there any way to cool it down while driving? Thanks |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Even in the recent "heat wave" here, my oil temps are no more than 180-190 at freeway speeds, unless I leave it in 4th and run it up to 80mph, in which case it can rise to 200 or so. Yesterday afternoon on 101, at 50-60mph, I could barely get the oil temps UP to 180. Totally stock cooling system on a Type IV.
Lo-Fi Version | Time is now: 4th July 2025 - 11:42 AM |
