Weber Tuning help..., my webers need some love |
Aaron Cox |
Jul 22 2006, 06:13 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Ok, little background before you can help.
44 idf's - freshly rebuilt. 34mm venturi's 50 Idles 135 Mains 195 Airs F11 Emul Accel pump jets are 50 i believe (new style weber with non roller cam pump - adjustable) Motor - 2L (71 x 94) 8.3: 1ish... Mallory unilite (12 deg/29 deg) CDI box, coil, etc (it aint foulin plugs with this setup.....) CB performance TALL manifolds, and linkage..... OK... so here is whatsup. Idles great, played with mixture screws etc and went thru the pre-tuning procedure as listed in Bob Tomlinsons weber IDF book.... Air bleeds are .5 turns open and all barrels are flowing about the same. Idle mixture screws are i think 2.5 turns out... and thjose are the settings. So the idle circuit seems to work OK. decent low end, Top end FLIES! but the transition is HORRIBLE. it falls flat on its face and sputters and then takes off like a rocket at WOT ( lean stumble? ) any one have any jetting suggestions for the above specs that may fix my stumle? I have some 32 vents i can try, but have a feeling it will take away some top end....(might be OK if i pick up some more low end) tired of fighting with them... today, car felt shitty. it was backfiring etc... hasnt done that in a while. i am gonna change intake manifold gaskets, and see if i have an airleak... any ideas??? |
Aaron Cox |
Jul 22 2006, 06:57 PM
im pretty sure stepping down a venturi size would be better. lets see if we can "mask" the problem with bigger fatter mixture on transition.
we tried a BIG/HUGE accel pump burst to try and make it better....to no avail |
Lo-Fi Version | Time is now: 6th June 2024 - 10:35 PM |
