electricial, guru's needed |
firstknight13 |
Jul 23 2006, 07:40 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
(IMG:style_emoticons/default/WTF.gif) i have a problem with my charging system... voltage reg works then doesn't... output goes from 14 to 11 or less with lights or other items on. must be bad ground or loose wire. ??? where do i start looking first? second?? thanks in advance!!!!! (IMG:style_emoticons/default/biggrin.gif) alternator has less than 5000 on it sometimes if i hit a bump all is fine (IMG:style_emoticons/default/WTF.gif)
Dr Evil |
Jul 23 2006, 09:51 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Well, if it goes to normal when you hit a bump then your components are likely working correctly and your circuit is having issues. You need to check you circuit board, plugs, connections, wires all one by one and see if you find any in disrepair. Your alt will put out 14 just fine, if when you put on lights and such it drops then your regulator is out of the circuit due to its connection or other malfunciton concerning it. Its sole job is to keep the to voltage at the battery semi constant to cope with heavy draw or lack there of.
Definetly check your circuit board. It could have a corroded run in the regulator circuit. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:57 PM |
