> Tire temps, For you track driver/racer types
campbellcj
post Feb 28 2003, 10:06 PM
I can't Re Member
OK, I know that the general concept of tire temps (pyrometer reading) is you want to check your alignment and suspension setup by looking for even or "logical" temps across the tread of the tire (outside, middle, inside) and also from front-rear and side-side.
Is there good detailed write-up somewhere explaining what different flavors of temp readings mean and what to do about it (corrective action)?
Also, what is considered a good operating temp for typical DOT-R tires like Kumhos? If your tires are "cold" or "hot" compared to what is the desirable range, what does that really mean (corrective action)? In other words if I have even temps, but low 100's instead of upper 100's or low 200's, does that mean I should just push harder in the turns, or what?
Mildly Confused,
Zeke
post Mar 1 2003, 04:40 PM
Never left, but not right....
Depends on the brand and the model of the tire. Some tires "come in" sooner. The manufacturer should have a data sheet for recommended camber settings and optimal tire temps. This has to be true because at too high a temp, the tire will blister. Before the tires blister, they should feel greasy on the track. But if only one portion of the tread is getting real hot, you won't notice it that much in the handling. You need to get the alignment right before you push it too hard. This all IMHO.
- Lo-Fi Version Time is now: 3rd July 2025 - 11:24 PM
