> BMW FRONT CALIPERS-you may be wrong
Krieger
post Jul 24 2006, 09:49 PM
I keep hearing this idea that BMW calipers add more heat vs stock caliper. I am not a physicist but any 2000 lb car going 60 mph with stock brakes is going to generate a certain amount of heat. Take the same exact car with smaller calipers (yes smaller) does it generate less heat? I don't think so. It is going to generate the same heat. The only thing that may change is the brake distance and time required to stop. Perhaps this extra couple of seconds it takes to stop allows more time to cool the brakes a tiny bit more, oh but your heating them longer. BMW calipers will add the same heat but faster. That is it. Other points are: the BMW rotors that these calipers were originally designed for are really close in diameter and thickness to our 914s. I'm sure someone will eventually post them. These BMW 320's were quite a bit heavier than our 914s as well. BMW used this combonation for 5 years it must have been a decent.
brant
post Jul 24 2006, 10:32 PM
I stand alone on this club in that I really like the KFP's for track work.
but I also have used portefields in multiple street cars with some track experience.
I'm not the autox guru... but I don't think you can go wrong with the portefields. probably the Street version if you putting that many road miles on.
I'm guessing that once you change pads you won't have to work very hard to lock up at will...
more importantly, you will stop faster and be more resistant to heat fade since a competition pad is designed to work best under a competition heat range...
however, you will dirty your wheels a lot more and need to learn different brake techniques including modulation...
oh... you may or may not start warping your rotors too.
ha
Krieger914   BMW FRONT CALIPERS-you may be wrong   Jul 24 2006, 09:49 PM
Dan (Almaden Valley)   Check with a BMW repair shop or someone with direc...   Jul 24 2006, 09:56 PM
alpha434   Did you say that all in one breath? Joke. It...   Jul 24 2006, 10:12 PM
Krieger914   I did this conversion 6 years ago, 11,300 miles, 5...   Jul 24 2006, 10:13 PM
alpha434   Soooo. Braking distance will not change with the c...   Jul 24 2006, 10:14 PM
brant   wow... you need better pads. pads are a wear ite...   Jul 24 2006, 10:16 PM
Krieger914   So you don't think they do more work than the ...   Jul 24 2006, 10:21 PM
alpha434   Can you lock 'em up with the the stockers? Or ...   Jul 24 2006, 10:24 PM
alpha434   Pads are going to be important though. Better pads...   Jul 24 2006, 10:25 PM
Krieger914   I can lock them up with the BMWs, but it takes a l...   Jul 24 2006, 10:28 PM
alpha434   Good. Now just wait to see if you've got heat ...   Jul 24 2006, 10:32 PM
brant   I stand alone on this club in that I really like t...   Jul 24 2006, 10:32 PM
Krieger914   What are KPFs? Not for this car, but I'm buil...   Jul 24 2006, 10:39 PM
lapuwali   The whole point of BMW calipers (or any other cali...   Jul 24 2006, 10:50 PM
alpha434
  Jul 25 2006, 11:19 AM
Bleyseng   I switched out my recently rebuilt fronts for a se...   Jul 25 2006, 11:26 AM
jhadler   Goign back to the pad question. The Porterfield...   Jul 25 2006, 12:35 PM
Lou W
- Lo-Fi Version Time is now: 16th July 2025 - 12:09 PM
