914-6 Idle speed rises as engine warms up |
kenschipper |
Jul 25 2006, 09:36 PM
Member Group: Members Posts: 186 Joined: 5-May 04 From: San Juan Bautista, CA Member No.: 2,025 Region Association: Northern California |
I have a completely stock 914-6 - weber carbs. When the engine is cold the car idles about 900 RPM. As it heats up the idle speed increases until it is idlying at about 1700 RPM when fully warmed up. It starts and runs fine. Just the high idle. Ambient temperature is currently around 85 degrees.
Since it is temperature related I'm currently thinking mabye a vacuum leak...loose manifold bolt. Any ideas on this one? Ken Schipper |
Joe Bob |
Jul 25 2006, 10:36 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Do you use the fast idle handle when cold? It's that handle next to the gear shift.....
If you don't....my guess is that the idle is set to high for warm running and it needs to be turned down.....cold starts, pull up on the handle...when warm push down. It's also a poorman's cruise control. Triple Webers do not have an electric or manual choke....just that fast idle thingy.... |
grasshopper |
Jul 25 2006, 10:43 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
Do you use the fast idle handle when cold? It's that handle next to the gear shift..... If you don't....my guess is that the idle is set to high for warm running and it needs to be turned down.....cold starts, pull up on the handle...when warm push down. It's also a poorman's cruise control. Triple Webers do not have an electric or manual choke....just that fast idle thingy.... hey Z, could you illustrate more on the "fast idle handle"?? was it just on stock sixes?? I have never heard of it being done in a six conversion. It sounds like a nice thing to install in a six conversion. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:18 AM |
